Honda CR-V & Element 2WD & 4WD Element & CR-V
Honda Element intermittent vibration
Old Jul 25, 2018 | 11:35 AM
Nor7's Avatar
Default Honda Element intermittent vibration
2008 Element manual transmission. The steering wheel shakes/vibrates at a frequency similar to the tire rotation frequency. Can be felt between 50 and 100 km/hr. Intermittent. Had a front brake
job 2 weeks ago. Had rotors and pads replaced. Comes and goes at this point. Started yesterday.
Old Aug 2, 2018 | 09:56 AM
suldy's Avatar
Default Re: Honda Element intermittent vibration
2wd or 4wd?
If 2wd:
could be wheel balance issue. maybe one of your weights fell off. also check lug nuts.
if 4wd:
could be the 2 issues above
-could be drive shaft u-joints
-could be center support bearing
-could be rear diff rubber mount
Old Aug 2, 2018 | 10:29 PM
holmesnmanny's Avatar
did it happen after the brake job ? does it do it moreso when pressing the brakes ?
jumpin4abeat
Aug 12, 2011 06:36 AM
JSA
May 17, 2011 04:01 PM
JRizEJ6
11
Jul 11, 2008 07:25 PM
redline7
Apr 19, 2008 12:38 PM
cccya
Oct 25, 2002 06:06 PM
