ITR Coil spring insulator/isolators?
Old Jul 22, 2018 | 01:13 PM
tony_2018's Avatar
Fish Twig
Default ITR Coil spring insulator/isolators?
Hi ITR owners,
So when doing maintenance on my car I noticed that these insulators/isolators crumbled and broke off of the springs. I was wondering if you guys ever found a replacement. I look at oem parts site but they only show the springs, thats it. Let me know.
Old Jul 23, 2018 | 06:23 AM
itrdave's Avatar
Default Re: ITR Coil spring insulator/isolators?
Pulled my deteriorated insulators out couple days ago... Called a couple Acura dealers and they knew nothing about these parts - hard to believe they are not serviced.
Old Jul 23, 2018 | 08:36 AM
dave7's Avatar
10 Year Member
They are discontinued afaik. But you can get them for other acura models, not sure if that that would work tho lol. I've wondered how they are installed. 3m tape?
Old Jul 23, 2018 | 08:50 AM
itrdave's Avatar
To be clear, I am talking about the sleeves that fit around the upper 2 coils of the rear springs. Not aware of any other model that has progressive rate rear springs for which these parts are used.
Old Jul 23, 2018 | 01:54 PM
stin1's Avatar
Loved
Community Favorite
Maybe you have to buy the whole spring? I have ran into the oem parts for this on a bulb for our cars. The cover isn't shown in the Acura system and the bulb I received was clear instead of amber. On my civic there was a nifty little support that helped support the front bumper on the fender. Honda system doesn't show it either as existing. Normally we get to see the disappointing discontinued on parts.
Old Jul 23, 2018 | 08:03 PM
tony_2018's Avatar
Fish Twig
oh hell no.
Yeah I was talking about the rear springs.
Old Jul 26, 2018 | 02:36 AM
Tom B's Avatar
What are they for? Noise reduction? Mine are still in decent condition but could use a clean and some 3M tape or glue.
Old Jul 26, 2018 | 04:06 AM
itrdave's Avatar
The coil sleeves (2) per spring are covering the upper 2 coils on each spring. The springs are progressive rate - 190 lb/in for ride initially, then increase to 250 lb/in in corners as spring compresses further, to provide the awesome cornering balance ITR Is known for.
The sleeves do 2 things - first is to prevent the upper 2 coils from contacting each other, which would wear off the paint, cause corrosion and lead to spring failure. The 2nd is to make the transition point to the higher rate happen at a specific compression distance. Without the sleeves, cornering balance is not what it is supposed to be because the effective spring rate is lower than intended over most/all of the outside wheel travel
Old Jul 26, 2018 | 05:33 AM
tony_2018's Avatar
Fish Twig
it sucks that there's no replacement. I know tein sells insulators
TEIN.com: Silencer Rubber - PRODUCTS
but unsure if they'll fit on the springs.
Old Aug 1, 2018 | 06:12 AM
itrdave's Avatar
Found Eibach sleeves sold at Summit etc for $15 ea...
Old Aug 1, 2018 | 08:22 AM
dave7's Avatar
10 Year Member
Have a link?
Old Aug 1, 2018 | 09:32 AM
itrdave's Avatar
https://www.summitracing.com/search/...spring-sleeves
Old Aug 11, 2018 | 02:49 PM
tony_2018's Avatar
Fish Twig
Was just about to post back about that. Do I get the smallest size? probably so. Will report back.
Old Aug 11, 2018 | 03:32 PM
dave7's Avatar
10 Year Member
Yea I was wondering which size to get from that link too.
Old Oct 26, 2018 | 10:27 AM
Tom B's Avatar
I just installed the Tein ones in size medium. Needed 3 per side on my '98 Spec JDM suspension.
Old Oct 28, 2018 | 12:33 PM
stin1's Avatar
Loved
Community Favorite
Three per side, did one box include enough insulators ,or we need to buy six insulators? Very helpful. Thanks for updating this.
Old Oct 28, 2018 | 11:04 PM
Tom B's Avatar
They come in packs of two so I used three packs.
Old Jan 12, 2019 | 07:38 AM
tony_2018's Avatar
Fish Twig
Interesting, I use these but yes you need to order 3 sets because each package comes with 2 so the 3rd set will cover what part of the coil you didn't cover. See images.
Old Jan 12, 2019 | 10:13 AM
Tom B's Avatar
That's it. I used 3 per side, same as OEM.
Old Jan 12, 2019 | 10:44 AM
tony_2018's Avatar
Fish Twig
I need to order 1 more, but for now I spaced them to where all 3 coils should have some cushion.
ktown-r
Jul 1, 2011 01:10 AM
DC2B18cya
Dec 13, 2008 04:08 PM
jeffchaisi
Feb 16, 2005 12:17 AM
FrostyDC4
Jul 26, 2004 03:39 AM
HapiHonda
May 31, 2003 08:34 PM
