My 1992 Honda Accord cuts out in middle of the race
Old Jul 15, 2018 | 01:05 PM
Troy Dulaney's Avatar
Default My 1992 Honda Accord cuts out in middle of the race
Ok so I have a 1992 Honda Accord that cuts out and loses power around 13 to 16 laps in and car warms up. I know it's not over heatyits like it cuts out or loses fuel. I put it in 1st and it comes back alive. Has cost me 3 wins now with 3 laps to go and just want to fix the problem. Any help you guys can give in what it may be please help me....
Old Jul 15, 2018 | 04:09 PM
GhostAccord's Avatar
Default Re: My 1992 Honda Accord cuts out in middle of the race
What's your setup, stock or modified?
Does the check engine light come on?
Do you have any sort of system that can monitor the ECU and sensors?
Old Jul 16, 2018 | 02:10 PM
Stock except advance timing to about 3000rpms. But it did this before I advanced the timing.
Old Jul 16, 2018 | 02:11 PM
As far as no check engine light and no it's to old for ODB 1 code reader
Old Jul 16, 2018 | 02:19 PM
Old Jul 19, 2018 | 03:18 AM
grumpys93's Avatar
You can use a paper lip to jump the connector to cause the CEL to throw any codes it has. The connector is under the glove box near kicker panel. It’s a 2 pin blue connector.
Old Jul 19, 2018 | 03:42 PM
Where you say it only happens after X amount of time and after it has warmed up. Heat soak effecting the IAT and timing is the only thing I can think of right off hand. Might want to try a different temp thermostat or wiring your fans to run constant.
mlueck
Apr 18, 2007 09:54 PM
blindman
Apr 11, 2006 12:39 PM
tedog69er
Mar 1, 2006 06:45 AM
