Please help!
Old Jul 18, 2018 | 07:40 PM
Nick Pope's Avatar
Default Please help!
I own a 97 Acura cl 2.2 Manual that recently wouldn’t start. After having it at a shop they told me the “keyless entry unit” wasn’t grounding. So I basically need a new one.
After more research I found what I believe to be the unit under the passenger seat.
So so my question is, how could that unit stop my car from starting and where can I get a new unit at? I can’t seem to find one online
Old Jul 19, 2018 | 05:41 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Please help!
It has a keyless/security control unit. If the car doesn't start, it may be due to the security control unit not sending the ground signal to the Starter Cut Relay.
If it is due to the control unit and you can't locate a replacement control unit; at the control unit, cut the starter cut relay control wire (usually a grn wire) and splice a spare piece of wire to it, then ground the wire. There is a ground bolt for the unit located under the carpet area of the passenger seat.
Old Jul 20, 2018 | 11:09 AM
Nick Pope's Avatar
I really appreciate the help! But I am a little confused, you said “cut the starter cut relay control wire (usually a grn wire)” which wire should it cut? If not both.
Also, sense it is the control unit not being able to ground. Would I be basically redirecting the ground and creating my own ground for it?
Old Jul 20, 2018 | 11:31 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
There is only one relay control wire from the security unit. I don’t have the CL circuit diagram; but, on an Accord, that wire is Grn.
Since the security unit may not be sending the ground,
you will be directly grounding that wire.
jp37421
Nov 11, 2012 01:30 PM
KLUE
Oct 14, 2009 08:01 AM
BoS_DC2
Mar 4, 2008 05:37 PM
chrisnova
Aug 10, 2005 08:22 AM
