Purposefully overfilled manual transmission bad idea?
Old Jul 13, 2018 | 06:54 PM
WaryDriver's Avatar
Default Purposefully overfilled manual transmission bad idea?
Wasn't shifting into reverse or first gear smoothly and had the idea of tilting car on jack so I could overfill by like 0.3 us quarts thinking mechanisms would be more oiled. Normally would take 1.9 and I put 2.2 probably.
Will I lose horsepower from drag and overheat the gearbox from more drag? Will I damage the seals? Will excess fluid escape somehow? Smelled like burned transmission fluid a few days after driving and getting out of my car.
Well theres good news it shifts into every gear smoother even 1st and reverse smooth. Could just be from New oil but could be since I overfilled eveeytbings getting more lubricated. Am I going to burn up my gearbox though or cause damage though?
Civic 1998 DX
Old Jul 13, 2018 | 08:40 PM
Chance EG's Avatar
Default Re: Purposefully overfilled manual transmission bad idea?
Overfilling the trans case can cause the fluid to foam up, which isn't good. Can also cause an increase in pressure when you're actually making the shifts, which in turn increases the heat on the gears.
Basically, no it's not a great idea as a fix.
Old Jul 13, 2018 | 09:13 PM
tony_2018's Avatar
Fish Twig
But by all means, if you want to keep that much in there and document what happens cool beans.
Old Jul 14, 2018 | 03:23 AM
civic402lx's Avatar
If you think you are smarter then hinda engineers, then go ahead.
MMMGIRL
Apr 11, 2014 06:06 AM
jajao555
Sep 20, 2012 03:48 PM
313hitman
Mar 20, 2009 06:50 PM
JDM_J
13
Jan 22, 2009 04:01 PM
94eh2
Nov 20, 2006 11:28 AM
