Honda CR-V & Element 2WD & 4WD Element & CR-V
2002 Honda CR-V trans leak.
Old Jul 13, 2018 | 08:32 AM
ColJac's Avatar
Default 2002 Honda CR-V trans leak.
Hi,
So I’ve got a 2002 Honda CR-V, got it from auction after salvage sale. Car has been repaired is running and driving. Question is, it seems to be leaking trans fluid. I did replace both the A/C condenser and the radiator, everything seems right and OK. I will be rechecking my work tonight I built the car for my nephew.
Is is there a common leak on the 02’s? Is there something else I should be looking for with the trans for the leak. I will be double checking the trans cooler lines to the radiator and
anything I moved/repaired during the rebuild.
Thanks for the help
Old Jul 14, 2018 | 08:15 PM
Audripulls's Avatar
Default Re: 2002 Honda CR-V trans leak.
Axle seals ?
Old Jul 16, 2018 | 01:59 AM
ColJac's Avatar
Update:
Found the issue to be the flare nut fittings for the trans cooler going to the radiator. One of the lines got kinked when I tightened everything, the kink created a small hole in the high pressure line allowing the vehicle to seep fluid during idle and driving R&R line, vehicle is no longer leaking.
Thank you.
PhoebeK
Honda Civic (2006 - 2015)
Sep 3, 2017 07:08 PM
Rob97'SH
Aug 30, 2008 10:01 AM
turbotaylor
Jan 29, 2007 06:21 PM
