Bouncing RPMs/stutter just under 3000K
Hello all. I have a 2000 manual with a built motor and a turbo setup. The built motor only has about 3,000 miles on it. I've been experiencing a problem with stutter and bouncing RPMs lately. There are no issues at idle, but while steadily driving anywhere from 25-45 mph, and mostly in any gear, at around 2800-3000 RPMs, the needle will steadily bounce up and down throughout a 200-300RPM range and the car stutters while doing so. Anything over 3000, there is ZERO issue. Just to rule them out, the IACV is a converted 2-wire (for OBDI compatibility), the fuel pump is new (a Walbro 255), new ID 1000cc injectors, wires, plugs and a boat load of other performance parts. I've read a few posts online that point to a distributor issue. Can anyone shed some light on this as to a starting point to diagnose or is this a common problem any of you have experienced?
Im having the same issue as you bro. My 95 Accord ex manual tranny has had the engine rebuilt as well about 4 years ago, Ive swapped out my iac valve, egr valve, my fuel pump and strainer and fuel filter in 2015, my oxygen sensor, just recently put a used throttle body from another 95 accord ex... I dont know where to look for the problem now... if you and anyone else have any advice, they will be heavily appreciated
bluelights81
Jul 13, 2018 08:45 PM
xtreemx98accord
Dec 14, 2006 05:52 PM
