Troubleshooting: 2000 Accord turbo w/ unstable idle under 3000K
Hello all. I have a 2000 Accord manual with a built motor and a turbo setup. The built motor only has about 3,000 miles on it. I've been experiencing a problem with stutter and bouncing RPMs lately.
There are no issues at idle, but while steadily driving anywhere from 25-45 mph, and mostly in any gear, at around 2800-3000 RPMs, the needle will steadily bounce up and down throughout a 200-300RPM range and the car stutters while doing so. Anything over 3000, there is ZERO issue.
Just to rule them out, the IACV is a converted 2-wire (for OBDI compatibility), the fuel pump is new (a Walbro 255), new ID 1000cc injectors, wires, plugs and a boat load of other performance parts.
I've read a few posts online that point to a distributor issue. Can anyone shed some light on this as to a starting point to diagnose or is this a common problem any of you have experienced?
re: Troubleshooting: 2000 Accord turbo w/ unstable idle under 3000K
Have you had the car tuned? What AFR's are you seeing in that RPM range? Any data logs?
There's a few different things that could cause stutters or jumping in the mid range. Either fuel or ignition related, no way of telling at this point.
bluelights81
08-16-2018 08:34 PM
Jobables
05-24-2013 04:23 AM
Nocturnal
06-03-2008 03:09 PM
361 accord
05-16-2008 08:25 PM
