Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Starting issue 14 stick shift
Old Jul 12, 2018 | 08:37 AM
amor1210's Avatar
Default Starting issue 14 stick shift
So i have an accord sport stick shift and no push button. I see issues with automatics with push buttons. Anyone else have issue where its intermittent. It does happen all the time and sometimes takes 2 to 15 key turns before it kicks over. Wife drove it yesterday and she said could been coincidence but took it out 3rd gear to neutral and started. Ive always put car in neutral before a start and you need press on clutch to crank car which would bypass any such gear issue. I drive far and alot for work and dont want to be stranded two house away. Anyone seen or know a fix for this? I know dealer is going to say if not happening i cant diagnose.
Old Jul 13, 2018 | 06:08 AM
foumer's Avatar
W95 gives me a hard-on
Default Re: Starting issue 14 stick shift
Mine has a lot of mile and no starting issue. Check the clutch switch. Could be the starter letting go.
Old Jul 13, 2018 | 06:10 AM
amor1210's Avatar
That’s what I thought because stick shift requires press of clutch to start. Isn’t there way to disable that like they do when you install remote starts?
cdela209
Jan 27, 2018 01:18 PM
bmoreb18c1
Jul 20, 2013 07:17 PM
jaydem7
12
Sep 2, 2007 05:12 PM
ash.zero
Jul 23, 2005 08:29 PM
fishin9975
May 15, 2004 08:46 PM
