Ran Tranny Fluid in Clutch Hydraulic system. Asking for a Friend
Old Jul 9, 2018 | 02:12 PM
killa31's Avatar
Default Ran Tranny Fluid in Clutch Hydraulic system. Asking for a Friend
Hey guys, so my "friend" accidental did something ridiculous and had tranny fluid running thru his clutch lines for a bit until the clutch ultimately lost pressure. Now Im trying to fix it by putting dot 3 in it and getting all of the fluid out. The problem is that I'm getting pressure momentarily and then it slowly falls to the floor. Should I keep bleeding it? Did I (I mean my friend) break the hydraulic lines somehow??
Edit: Also Ive tried bleeding it a few times.
Old Jul 9, 2018 | 02:19 PM
Chance EG's Avatar
Default Re: Ran Tranny Fluid in Clutch Hydraulic system. Asking for a Friend
The clutch line itself should be fine after you've completely bled out all of the trans fluid. As for the slave and master cylinder, I really have no idea.
Make sure you're using a proper bleeding method and there's no air in the system.
Old Jul 9, 2018 | 02:25 PM
mk378's Avatar
Oil based fluids will ruin the rubber used in brake and clutch systems. You need to remove and discard both cylinders and the rubber hose, then flush out the metal line with solvent and rinse it with brake fluid. Replace the cylinders and hose with new ones.
Old Jul 9, 2018 | 02:33 PM
killa31's Avatar
Im going to try to bleed this sucker first. The last thing i want to do is replace the exact things that I was just replacing, but if Im not able to get any pressure this is probably what Ill be doing
Old Jul 10, 2018 | 05:59 PM
94EG8's Avatar
Seagull Management
You're wasting your time trying to bleed it, the transmission fluid will ruin anything rubber almost instantaneously. Remove the master cylinder, slave cylinder and rubber line. Flush the steel hard line with brake clean followed by a little clean brake fluid, the install new cylinders and a new flex hose.
sing
May 20, 2013 05:28 AM
projectr
Aug 19, 2008 01:37 PM
redline7
Feb 17, 2008 12:24 PM
teddy_dc2
Nov 21, 2005 12:03 PM
Shotman
Jan 12, 2005 05:48 PM
