2005 Civic Dx Oil Leak
My 05 Dx Civic coupe is leaking oil in the oil pump crank seal area. I'm sure it's the seal in the oil pump but I'm trying to research and I see a post talking about it's easy to mess that seal up when you put a new one and that it's better to replace the whole oil pump. Not too sure of that. Just wanna get some insight before I make an order. ( https://honda-tech.com/forums/acura-...-seal-2886424/ )
If you follow the service guide, the seal is easy. But a pump swap is less prone to messing up, if it is the pump. You're going to pay a lot more for a pump though
Yea looking at about 7$ for the seal and about 285$ for the pump assembly. ( hondapartsunlimited.com ) I always try to buy OEM. Any personal recommendations from past experiences from anyone on oil pump or oil pump seal that is. I mean if it's done right it shouldn't be a problem. But is it that difficult to do it right?
I've where you can get the seal by itself on ( https://www.hondapartsunlimited.com/...-strainer-scat )
Mr. Future
Nov 22, 2015 07:46 PM
USDM 4G VTEC
Sep 9, 2003 01:19 AM
