Honda CR-V & Element 2WD & 4WD Element & CR-V
1999 Honda CRV Fuse 56 keeps blowing
Old Jul 8, 2018 | 10:03 AM
josh beers's Avatar
Default 1999 Honda CRV Fuse 56 keeps blowing
Hi all,
I have scoured through the forums, but I just am not sure how to diagnose this issue correctly. Any help would be much appreciated.
AC air blows, but it blows warm air. I realized fuse 56 was blown so I replaced it. The air was cool again for our one hour ride, but then the next day it did the same thing and the fuse blew again.
What I found on the forums was to unplug the condenser fan and put a new fuse in and see if it popped. This is where I am kind of stuck. Since the fuse doesn't pop for quite some time when replacing it do I leave the condenser fan unplugged for that long? Is there anything else I should do in the meantime or any other test since it's not popping right away?
I think after this, the forums say to unplug the compressor clutch. If I can get the first step complete then I can move on to this one and would love to know how to unplug the clutch when the time comes.
Thank you in advance!
I found this on another post. This is Fuse 56 which is blowing on my CRV.
Fuse box from another post
Old Jul 25, 2018 | 11:37 AM
EL Vap133's Avatar
Default Re: 1999 Honda CRV Fuse 56 keeps blowing
That's odd, have you done any wiring on the car recently?
Old Jul 25, 2018 | 11:49 AM
josh beers's Avatar
Thanks Vap133...Super strange, but no I have not done anything on the car at all concerning wiring - just new tires. This issue happened a while back and since I'm new to the forum it just posted recently.
While troubleshooting, I unplugged the condenser fan and the fuse didn't blow. I also made sure wires were not frayed, in bad shape or looked strange and then plugged the condenser fan back in. I replaced the fuse with a new "BETTER" fuse (other one I had was garbage). Now it's been working like a charm ever since! Go Figure. I'm happy it's working and hope this post doesn't jinx it.
For anyone looking into this same issue, start with replacing the fuse, then unplug the condenser fan and run it for a while, then adjust your wiring to make sure it's not touching or frayed.
For all I know it could of been the clip for the condenser fan was just shorting it out b/c it rattled loose a little.
Thank you everyone for posting on the forum and for all the answers! Very helpful!
Cheers!
Old Jul 25, 2018 | 12:00 PM
EL Vap133's Avatar
Wow, where did you get the better fuse from? Was the one that blew the first time not the original from the manufacturer?
Old Jul 25, 2018 | 12:02 PM
josh beers's Avatar
I don't think the one in there was very good, was a light plastic and see through, just looked cheaper than all the others. I got a new one that wasn't as see through and A-OK so far! We'll see in another month what happens. HA HA
Old Jul 25, 2018 | 03:07 PM
EL Vap133's Avatar
Haha, hope you bought a stack of replacement fuses.
iwannarace
Nov 1, 2014 10:08 PM
demiseraph
Aug 5, 2011 05:12 PM
Aaron Cayabyab
13
Jul 22, 2011 09:15 AM
JettCRX
Jul 9, 2006 07:52 AM
tararan
Nov 13, 2001 09:47 AM
