2000 Honda Civic EX Coupe-possible engine swap
Old Jul 7, 2018 | 05:47 PM
RoundRockTX77's Avatar
Default 2000 Honda Civic EX Coupe-possible engine swap
Hello y’all!!!! This is my first post and wanted to see if anyone can help me out. I have a 2000 Honda Civic EX Coupe. Engine started to run hot, so I took the head in to get resurfaced. Head has been put back on the block, however the camshaft is not at 12:00 or TDC. Is it possible to still adjust the camshaft while it’s attached to the block?
I don’t want to have it towed to Honda and have them charge me $1,000 to do the job. That being said, I was thinking of going another way and that would be possibly adding a 2000 Civic SI engine and manual transmission swap. (I currently have an automatic) If anyone has any part numbers for this swap and any recommendations for places to get engines, it would be great!!
Old Jul 8, 2018 | 04:45 PM
holmesnmanny's Avatar
Default Re: 2000 Honda Civic EX Coupe-possible engine swap
as long as the engine hasn't been started you can reuse the head gasket so just pull the head, set it all to tdc and reattach it
then, before putting it all back together, put just the timing belt on and run a compression test
Old Jul 9, 2018 | 06:55 AM
Thanks!! I appreciate the information. I’ll update this message board when I’ve finished. Who knows, maybe someone can also learn about this.
Old Jul 9, 2018 | 08:43 PM
Freedo_Civegra's Avatar
Why the heck would you remove the head if the cam isn’t at the right alignment? If the crank is at TDC, remove the spark plugs and just rotate it 3/4 turn counterclockwise so that all the pistons are level, and set the cam where it needs to be. Then, rotate the cam 1/8 a turn clockwise. Next, slowly continue to turn the crank 1/4 turn counterclockwise and the cam 1/8 turn counterclockwise. Everything will be at TDC if you do this.
Old Jul 10, 2018 | 12:57 AM
Thanks, I appreciate the advice. I had the #1 cylinder TDC and the cam in alignment when I removed the head. When the head returned from the machine shop, the cam was at the 9:00 position. I assumed it would be TDC as it was when I dropped it off. I should have checked instead of assuming before installing.
Old Jul 10, 2018 | 08:25 AM
Kevs02Accord's Avatar
My thoughts, no need to remove the head.
Old Jul 10, 2018 | 10:51 AM
tony_2018's Avatar
Fish Twig
He probably had the head off to be serviced .....
tony_2018's Avatar
Fish Twig
Another thing is that the cam lobes shouldve been lined. If not put some oil on them before clocking them
Old Jul 10, 2018 | 12:21 PM
It was, but why would he need to remove the head to realign the cam?
Old Jul 11, 2018 | 01:58 PM
tony_2018's Avatar
Fish Twig
I might have skipped that part
Desean Brown
Jan 13, 2019 07:55 PM
Matt Patras
Nov 4, 2013 06:25 PM
slyda24
Jul 27, 2011 05:29 PM
youngbonzi
12
Jun 4, 2004 06:41 AM
