how do you know if distributor is bad?
Old Nov 12, 2002 | 09:15 PM
SIK IN DA HED's Avatar
New User
Default how do you know if distributor is bad?
just curious cuz i replaced everything ignition related and my car runs like ****.
Old Nov 12, 2002 | 09:17 PM
gsrvx's Avatar
New User
Default Re: how do you know if distributor is bad? (dlplayboy)
Define running like ****.
-Rod
Old Nov 12, 2002 | 10:30 PM
John-GSR's Avatar
Your tach needle mught jump around. I had that problem and linked it to my distributor. Ending up being a bad ground.
Old Nov 12, 2002 | 11:22 PM
Trac226's Avatar
Default Re: how do you know if distributor is bad? (John-GSR)
I thought my tach was messed up too, just turned out to be a fuse.
Old Nov 13, 2002 | 12:33 PM
New User
Default Re: how do you know if distributor is bad? (RK)
-Rod
lets see:
-spark plugs were white, which means its running lean, if not detonating
-car idles rough when i drive
-car stutters and bogs during idle, sometimes its cool, but constant bogging
-if i start my car and leave it at idle... it will be cool for a few minutes until it warms up and then boggs like crazy again
-feels like i got a 2step revlimiter built in (not a good thing)
Old Nov 13, 2002 | 01:17 PM
gsrvx's Avatar
New User
I had my car bog while driving around 2-3K rpm..actually sounded like a 2step like you said. Turned out to be ignition coil failure.
I've always had boggin, not as bad as the coil, and changing the spark plugs cured the problem.
I'd start with the cheapest...spark plugs. Then if those don't work, dist.rotor, then coil, ignitor, etc.
-Rod
Old Nov 13, 2002 | 01:30 PM
New User
well, i have a msd external coil hooked up right now. i wonder if thats the problem. i just took off the msd unit. other things might be going bad... gotta check em all out, too. *sigh* lots of work to do on my car...
DC4R27
Jan 22, 2009 09:55 PM
tamparacer
Sep 24, 2007 07:43 PM
rdssk8rcs1
Oct 24, 2006 04:13 PM
TorinRage
Mar 17, 2005 09:01 AM
chirp3rd
Dec 9, 2002 03:45 PM
