Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
TSX AC Woes
Old Jul 5, 2018 | 01:25 PM
carlove's Avatar
Default TSX AC Woes
Bought a 2007 TSX MT last year for the extra room and reliability.
AC compressor was shot, so I had that replaced along with the drier. Had the system evacuated and refilled by a shop.
AC will not blow cold past 85 degrees F. Works pretty well under 85 degrees F.
Does not work well at IDLE.
BOTH fans kick on, compressor clutch engages when AC is turned on and STAYS on. Disengages when AC is turned off.
These are the static pressures IE car turned off.
These are the pressures with the car on and ac running on Lo, full blast.
Do I have a blockage somewhere? Expansion valve? Please advise, as I live in Virginia and its hotter than a hoochie coochie right now. Thank you.
Old Jul 5, 2018 | 06:52 PM
holmesnmanny's Avatar
Default Re: TSX AC Woes
when the compressor explodes it sends shrapnel into the condenser which also needs to be replaced
Old Jul 5, 2018 | 07:20 PM
carlove's Avatar
The drier wouldn’t of caught most/all of the debris?
Old Jul 7, 2018 | 02:48 PM
the drier captures moisture and the filter element is not strong at all to begin with
Old Jul 11, 2018 | 06:01 AM
Ryanthegreat1's Avatar
That looks undercharged to me but hard to say without knowing the outdoor temperature when you took those readings.
xxjokoxx
Aug 23, 2010 12:51 AM
Davidss
Jul 16, 2009 05:51 AM
Civic Racer X 7
Aug 8, 2007 05:15 PM
vietnogi
May 24, 2005 08:01 AM
