brake lights stuck on
90 crx si
brake lights stay on even after the car and all lights is turned off.
draind my battery completly.
anybody had this before?
im thinking it could be bad brake switch or brake pedal ajustment or both.
any feedback welcome.
thanx
thanx
there is a switch on the pedal assembly, check that first...
The same thing happened to my brother's CRX. It's a small circular piece that goes on the brake pedal assembly where it meets the brake switch. The little piece cracked and fell apart. I simple glued a penny on there, until I could pull one of another CRX. You can also buy it from Honda, it's very inexpensive.
Later.
Later.
whats up. yeah i took a good look today, thats exactly what happened, little rubber pad cracked and fell out of the hole on pedal arm. took a 10mm bolt/nut (1/2in long) -screwed it toghther, solved now.
worked out real good.
thanx to all for feedbank and responses.
RanCRX
Jun 9, 2008 07:35 PM
you're on the right track...
