99 Accord fuel leaking after upgrading to inline pump
Old Jul 3, 2018 | 11:13 PM
joedaddy's Avatar
Default 99 Accord fuel leaking after upgrading to inline pump
hello,
I eliminated my stock in-tank fuel pump for an edelbrock in-line pump and now I have fuel leaking from the return system and it appears to be leaking from the framework right in front of the driver side rear tire. Is there anyway I can bypass this area or eliminate the whole evap system? It’s leaking from inside the rear crossmember and i can’t figure out a solution because i can’t get inside the crossmember. The car has sat for several years and it used to not do this. ((
Old Jul 7, 2018 | 05:39 PM
joedaddy's Avatar
Default Re: 99 Accord fuel leaking after upgrading to inline pump
Bump
Old Jul 7, 2018 | 06:01 PM
joedaddy's Avatar
It leaks from inside the cross member just pastrhis fitting
It’s coming out of this weld
Old Jul 7, 2018 | 06:04 PM
joedaddy's Avatar
Diagrams from Honda book
Old Jul 7, 2018 | 06:29 PM
joedaddy's Avatar
The line that leaks comes out of this. There is a small fuel line that isn’t shown and it is represented by the red line and it is about 10” long and goes to a plastic elbow directly into the cross member. It leaks somewhere from inside the cross member. Fuel pressure is at about 20 psi. It didn’t leak before tho. What i want to do is pull the line off of the elbow and attach to it and run it to the tank and drill a new hole and install it he line into the hole, back into the tank. Will it work?
Old Jul 8, 2018 | 06:57 AM
joedaddy's Avatar
Some please help me!!!! ((
Old Jul 8, 2018 | 02:56 PM
holmesnmanny's Avatar
i would just put it back the way it was and see if it fixes it
Old Jul 9, 2018 | 04:40 AM
joedaddy's Avatar
I tossed the stock in tank pump, so i would have to get another one , but i was thinking that too. Ugh. I really want to use the nice one i got because i have a full built blick from JG Engine Dynamics the i am going to run, once my head gets finished.
Old Jul 9, 2018 | 08:10 PM
joedaddy's Avatar
Please help me!!! Someone has to know this fuel system well enough to help me, ugh ((
Old Jul 13, 2018 | 12:38 AM
joedaddy's Avatar
Bump
Kwish
Classic Hondas
Apr 23, 2012 01:01 PM
ahondaowner
Dec 31, 2008 09:48 AM
XJRiggs
Jun 20, 2004 02:25 PM
Excelerate
Oct 4, 2002 10:46 AM
