Honda CR-V & Element 2WD & 4WD Element & CR-V
Help! 1999 Crv Jerking issue
Old Jul 2, 2018 | 10:21 PM
FatboyNYC's Avatar
Default Help! 1999 Crv Jerking issue
So for some reason my car jerks really bad when i drive at 50-60mph. Its only when i turn my a/c on! i changed both idle air control valves and did all the belts. It's not the transmission because it drives perfectly fine with the AC off.
any ideas what could cause this? anyone else have this problem???
Here's a video clip
Old Jul 5, 2018 | 09:04 AM
UK-Kev's Avatar
Default Re: Help! 1999 Crv Jerking issue
sounds like the AC clutch kicking in and out
Old Jul 5, 2018 | 09:21 AM
2x0's Avatar
2x0
10 Year Member
Yup. AC compressor/clutch are failing.
Old Jul 10, 2018 | 03:23 PM
FatboyNYC's Avatar
so i changed my a/c compressor and it still jerks but now at lower speeds but not as bad as before. im pulling my hair out on this one!
Old Jul 10, 2018 | 03:37 PM
2x0's Avatar
2x0
10 Year Member
Still only when ac is on? What brand compressor did you get and who installed it?
Old Jul 10, 2018 | 10:39 PM
FatboyNYC's Avatar
denso compressor, my mechanic installed it. also my oil pressure light flashes when i press the brakes and come to a complete stop.
i checked the oil level and its fine. is the oil pump connected to the belts? is that whats giving me that jerking oil pump maybe?
i recently changed the oil to 5w-30 mobil 1 extended performance would that cause to flash?
Old Jul 11, 2018 | 01:45 AM
2x0's Avatar
2x0
10 Year Member
Does it still only jerk when ac is on?
Did said mechanic also replace the condenser, dryer, and flush the system? Once a compressor fails it will contaminate the system. If all of this is not done at the same time, that contamination can cause the new compressor to fail almost immediately.
Oil pump and type of oil will not cause this.
carlove
Acura TSX
Jul 11, 2018 06:01 AM
Bobs2008Civic
Honda Civic (2006 - 2015)
13
Aug 9, 2017 05:33 AM
PL_RACER
Jul 24, 2012 07:20 PM
johnehonda
10
Jul 4, 2012 08:13 AM
adan CRX
Nov 26, 2003 08:41 AM
