Tranny starting to grinding in 3rd with only 800 miles on rebuild
Ok. Here is the deal.
I have a 99 ITR motor and tranny in my 92 CX hatch. The tranny started to grind in 3rd after 3000-4000 miles after the install. I had the transmission rebuilt by a friend who works as a mechanic at Honda, so I know it was rebuilt correctly. I had a new 3rd gear, new synchros for third and forth, and all new bearings installed. Tranny worked great when the work was completed. I put about 800-1000 miles on the rebuilt transmission then it started to grind in 3rd again. Any suggestions on what could be causing this reoccurring problem? I have heard that the linkage for a jdm itr is longer then the gsr linkage and might be causing the problem. I have not physically measured the two yet. The car has just been sitting in the garage until I figure out what I want to do. Has anyone experienced this or have any suggestions?
Or stop beating the **** out of it. Is this from daily driving or is it from many track days? What kind of tires are you running at the track and on the street ? slicks ?
[Modified by SpooN Man, 8:53 AM 11/13/2002]
Anybody have any other advice?
f150harleytruck7
Jul 13, 2005 04:04 AM
jdmciviceg
Nov 14, 2002 07:18 AM
