h22a accord
Old Nov 12, 2002 | 08:15 PM
Acclude's Avatar
Default h22a accord
just done transplant in my 4th gen accord but no vtec engage n rev cut at 6500rpm could that b caused by a damage knock sensor
Old Nov 12, 2002 | 08:19 PM
WhoNeedsVtec's Avatar
Default Re: h22a accord (Acclude)
your vtec sensor is not being recoginized. that is causing your redline at 6500. what ecu are you using?
Old Nov 12, 2002 | 08:23 PM
Acclude's Avatar
Default Re: h22a accord (WhoNeedsVtec)
usin h22a ecu everything from prelude front cut
Old Nov 12, 2002 | 09:33 PM
h22a obd1 or obd2?
Old Nov 12, 2002 | 09:38 PM
Acclude's Avatar
obd1
Old Nov 12, 2002 | 10:02 PM
Nick M's Avatar
what cel did u throw?
Old Nov 13, 2002 | 05:13 AM
Stew Pidasso's Avatar
It could be in limp mode if your throwing a CEL...
Old Nov 13, 2002 | 05:14 AM
Gennady's Avatar
New User
Default Re: h22a accord (Stew Pidasso)
Limp mode usually limits you to 3500rpm or so.
Old Nov 13, 2002 | 09:05 PM
Acclude's Avatar
not throwing any cel at all
Old Nov 13, 2002 | 09:23 PM
purpl7duece's Avatar
mine did the same thing. it could be many things. Mine was just that the wires for the vtec were not on properly. Ones you see what code it is pulling you might have your answer.
Old Nov 13, 2002 | 09:32 PM
Nick M's Avatar
Default Re: h22a accord (Wont be beat)
My mis-wired vtec oil pressure switch in my swap put me in limp mode and a 6500 cutoff
Old Nov 13, 2002 | 10:00 PM
H22ABOY's Avatar
Default Re: h22a accord (Nick M)
yes a knock sensor can possibly, sometimes put you in safe mode. However most of the time..... no. I drive around with CEL 23 and I can vtec. Check to see if the vtec pressure solenoid is free of debris, you can remove it and clean out the oil screen. Make sure you have plenty of oil. and that the wires are hooked up. if everything is ok, make sure you have a p13 ecu.
Old Nov 14, 2002 | 06:57 PM
Acclude's Avatar
Default Re: h22a accord (H22ABOY)
ive done everything checked wirring ,vtec soloniod ,changed knock sesor how do i check to c if oil pressure switch is working??does ne1 know where i can p13 wirring diagram and a pinout chat
Old Nov 15, 2002 | 09:13 AM
Ryu's Avatar
Ryu
https://honda-tech.com/zerothread?id=329142
check that out...
btw i recently done my swap, my vtec is finally working after i replaced my fault ECU.. the First ECU they gave me was faulty, (had 4ws input as well!) the second P13 ecu they gave me didnt come with it
im getting a code 41 i think its the heater oxygen sensor.. but the car red lines at 7,500....
do you feel the torque in your car, my car sorta feels sluggish compared to my friends 4th Gen Prelude H22A
Old Nov 15, 2002 | 09:27 AM
Jason kiDD's Avatar
Default Re: h22a accord (Ryu)
Ryu without your O2 sensor completely hooked up your car is going to feel sluggish at anything under 4k. After that it'll scream. Make sure you get it hooked up properly and you should be fine..
As for the vtech woes, if you are not getting any CEL's then check to make sure that the oil level is good, car is warm, solenoid operational. Stuff like that.
Old Nov 15, 2002 | 09:42 AM
Ryu's Avatar
Ryu
Default Re: h22a accord (Jason kiDD)
is this the one that connects to the exhaust pipe right?
i got a feeling its got to do with the pin swapping of a6 and a11...
i did it today, but no effect maybe i had to reset the ecu?
i just reset the ECU... no more code now! yay
but car still sluggish..
[Modified by Ryu, 6:48 AM 11/16/2002]
Old Nov 18, 2002 | 08:25 PM
Jago's Avatar
my swap had no vtec when I finished. Rewired
the pressure switch and now it works.
Do you have the secondaries hooked up. if so how
did you do it?
Hondacontrol
Feb 12, 2012 04:22 PM
nelsond
Aug 7, 2006 12:45 PM
sick_accord
Oct 5, 2002 12:21 AM
Acclude
Sep 11, 2002 10:30 PM
