transmission shifting
Old Jun 28, 2018 | 04:23 PM
baseballnut57's Avatar
Default transmission shifting
out of the blue my trans was not grabbing and engine reved up to 3-4 grand then as I laid off pedel it started to work again but did it again I replaced the p0715 error code speed vvs but did fix it the mechanic said any help
Old Jun 29, 2018 | 12:26 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: transmission shifting
Year, engine, sub-model, mileage?
Old Jun 29, 2018 | 12:43 PM
fliplyricist1's Avatar
Could be a number of things. Clogged fuel injector, failing tranny, or even the tps sensor (which is known to do what you mentioned). I'd try testing the tps first with a multimeter and seeing if its within spec. Then dump some fuel injector cleaner in there for good measure.
Arsalan Ali
Honda Civic (2001 - 2005)
Jan 3, 2018 01:22 PM
TaikiDC5
Jul 30, 2011 01:17 PM
DonsEG
Jun 30, 2009 04:18 PM
Latinsonic
Mar 26, 2007 04:52 AM
JFG Kevin
May 18, 2006 03:58 PM
