98 Prelude Type SH
Old Jun 18, 2018 | 08:26 PM
murrc3459's Avatar
Default 98 Prelude Type SH
Heya there! I have a 98 Type SH. The h22 that’s in there has a spun bearing. And I’m trying to find another motor that is pretty much a plug and play that is pretty cheap. Yeah I know the h22 is the best out there I just don’t wanna spend 1400 on a motor at the moment. And a engine swap checklist? Like everything Id wanna do/get/transfer over to make it work. I’d also like to know what some good import sites are. Cheap and reliable.
Old Jun 18, 2018 | 08:35 PM
TimiK's Avatar
10 Year Member
Default Re: 98 Prelude Type SH
Its not going to be super cheap since you cannot use your old transmission so you have to buy whole engine with transmission there.
Ask a quote from your local machine shop that how much it would be to hone the block and change piston rings and bearings.
See that you also have to rebuild the swap engine too if you want to make it last (head, timing side, clutch, gaskets and seals etc)!
Either way its going to cost you more than 1400
Old Jun 19, 2018 | 06:51 PM
murrc3459's Avatar
Thanks! So a f20b wouldn’t drop right in with the old tranny?
Old Jun 19, 2018 | 08:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
No, only a H22A4 "SH" engine drops right in with the old transmission.
Old Jun 20, 2018 | 02:57 AM
TimiK's Avatar
10 Year Member
^ or jdm type s
Old Jun 20, 2018 | 09:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
^ or jdm type s
If it is one with the ATTS type transmission bolted to it... then yes, that engine too.
Aircooled_Pat
Feb 18, 2018 10:35 AM
carloc98
Mar 11, 2014 05:21 AM
NothingBUTasian
Jan 25, 2008 11:45 AM
adam62882
Feb 18, 2007 06:26 PM
jmflyd
Nov 1, 2004 02:56 PM
