K20A3 Engine - Top Dead Center?
Old Jun 18, 2018 | 02:29 AM
JoeBlow2017's Avatar
Default K20A3 Engine - Top Dead Center?
1) In the shop manual, they say turn the harmonic balancer (crank pulley) top dead center. Which cylinder is supposed be top dead center?
2) What is the best way to know if that cylinder is top dead center?
Old Jun 18, 2018 | 10:38 AM
thisguyaves's Avatar
Default Re: K20A3 Engine - Top Dead Center?
Cylinder 1 (or 4 honestly, they move together)
The "front" of the engine is typically where cylinder 1 is, that's the side that is furthest from the transmission and closest to the serp. belt. In K20 cars, that would be the (USDM) passenger side of the car. take the valve cover off and spark plug out from cylinder 1. Rotate the pulley until you see the camshaft gear markslining up with each other (there will be small nothches on intake and exhaust, 2 will point towards each other, I'm sure your guide goes into this.) then stick a pole, long screw driver, or other lengthy rod-object slowly into the spark plug hole of cylinder 1. I use a small parts grabbing tool thingy. It's now resting on top of your #1 piston. Rotate the crank pulley until that rod, and the piston, is at it's highest point. The cam gears should line up (or be close to it, if they aren't your engine is not in time.) If the cam gears aren't anywhere near lined up, you're probably at TCD exhaust stroke. Spin the crank another rotation.
Old Jun 18, 2018 | 10:42 AM
hopefully this helps. #1 can also be TDC of exhaust stroke, you want TDC of compression stroke. Look for those cam gear marks to line up.
sgull
Jun 11, 2013 01:32 PM
Civic-Kids
Mar 10, 2009 02:58 PM
aznpreludeSH
Aug 26, 2005 03:57 PM
silentbeatz
Aug 21, 2005 10:38 AM
red00gsr
May 30, 2003 10:05 PM
