97 accord engine swap
i may be wanting to do an engine swap on a 97 accord i recently came into possesion of, once i found out it has the non vtec in it. an option would simply be the f22b1 vtec, but from lurking here i see many other options exist. so my only limits are this; id prefer a drop in engine, i will be getting my engine from a junkyard or junkyard website, the engine should be able to withstand a turbo easily cuz im sure ill mess it up at first, and finally the engine should be easy to get upgrade parts for.
my assumed tier list goes like this to fit my parameters
1. simply drop a f22b1 and turbo it (read somewhere they handle turbos well?) con is low hp 145-160 avg i think
2. get a h22a and drop it in, with higher base hp (200-ish) and turbo it
3. k24a with conversion (pro is best horsepower and turbo option, con is cost and conversion work needed)
Xarpolis
Apr 4, 2004 12:29 PM
