Head Rattling
Old Jun 17, 2018 | 03:27 AM
BobTheEG's Avatar
Post Head Rattling
Dear Users
I have a b18c out of a JDM integra type r in my eg civic and it makes a very loud rattling on cold start from the head. It gets quieter as the car heats up although is still there.
I was curious to see if anyone had similar problems and knew what it was and the best way to fix it.
Regards
Jesse
Old Jun 17, 2018 | 01:24 PM
Freedo_Civegra's Avatar
Default Re: Head Rattling
Valve lash?
Old Jun 17, 2018 | 04:29 PM
Audripulls's Avatar
I would've said VTC actuator but not the right car or engine, sounds like a valve clearance issue maybe?
no codes ? What's the map Voltage at ?
Old Jun 17, 2018 | 05:57 PM
BobTheEG's Avatar
No, there is no codes, i'm going to take the valve cover off this weekend and check the clearance.
I comp tested the engine and it has
cyl 1 - 245
cyl 2 - 245
cyl 3 - 240
cyl 4 - 240
So i'm pretty certain it doesn't have any issues with valves sealing.
Old Jun 17, 2018 | 06:09 PM
BobTheEG's Avatar
If it is valve lash does anyone know what sort of feeler gauge I should use for a b18c type r engine?
Old Jun 17, 2018 | 06:14 PM
I can’t remember, but I think the intake is .006” and exhaust is .008”.
What’s your oil pressure running?
Old Jun 17, 2018 | 06:30 PM
BobTheEG's Avatar
Im not sure, ill have to get an oil pressure gauge to see because I have a stock eg dash.
Old Jun 17, 2018 | 08:36 PM
BobTheEG's Avatar
Will it destroy the engine if I keep driving it if it has valve lash whilst i wait to fix it? I need the car for work purposes.
Old Jun 29, 2018 | 11:27 PM
BobTheEG's Avatar
For those having a similar problem, I found out that it was the distributor making the rattling.
Old Jun 30, 2018 | 03:13 AM
I don’t think the slack in the valve lash would destroy the engine, but too tight would.
What the heck was wrong with the distributor?
Old Jul 13, 2018 | 06:41 PM
BobTheEG's Avatar
HonestlyI I have no idea. I have been looking for a second hand one but they are very scarce for these engines.
In the meantime I have been driving the car regularly and it hasn't given me any issues or gotten an louder.
Old Jul 14, 2018 | 06:59 AM
850Fabrication's Avatar
You aren't going to fix it by waiting for someone to give you an answer. take the valve cover off and check the valve lash and adjust if necessary. Then see if the sound went away.
si937
Jul 25, 2006 02:18 PM
maxxd97
May 23, 2005 08:12 PM
turbociv
38
Jul 4, 2004 11:33 AM
drjondurst
11
Jun 7, 2003 11:15 AM
Yuleluder
Sep 16, 2002 09:43 AM
