ELD disconnect
Hello,
Can you help. I am wanting to disconnect the ELD on a Honda CRV 2002. Reason is on my dual battery system it is causing the Isolator to switch on and off all the time.
Thank you
Brian
Thank you
Brian
Essentially, the ELD Bypass can be done like the following:
Do at your risk!!!
1. Cut Green/Red wire from ELD to PCM.
2. The half of Green/Red wire coming from the PCM (ELD Unit Input) goes to the POLE of the toggle switch (12VDC SPDT Toggle Switch).
3. The other half of the Green/Red wire from the ELD (Load Output) goes to THROW 1 of the switch; the POLE would be switched to this THROW to have ELD to work normally.
4. THROW 2 goes through an 820-ohm resistor to the black ELD ground wire at the plug; switching to this THROW would bypass the ELD and cause the alternator to turn on and charge the battery all the time. – Important: “Do not ground this resistor to chassis ground. “
Do at your risk!!!
Do at your risk!!!
Do at your risk!!!
Ronin Panda
Jun 14, 2003 11:18 PM
