Suspension & Brakes Theory, alignment, spring rates....
rotor shield redundant?
Old Jun 15, 2018 | 05:19 AM
RobRac's Avatar
Icon5 rotor shield redundant?
Most people get rid of their rotor shields completely or partially while installing bigger rotors, still, I guess they are not just useless pieces of tinware. I may be too meticulous about my BBK project, but I'd rather have the shields if possible. I wondered if any bigger honda shields could work (I'm installing 350z "brembo" rotors on my '17 accord coupe). My rotors are 12.8" (about 325mm) while eg. honda pilot's rotor diameter is 12.6" (320mm). Still too little. Are there any bigger honda/acura shields that could work? Is such a swap worth the effort?
Old Jun 15, 2018 | 07:51 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: rotor shield redundant?
I kept my factory shield with my Advics/350Z BBK.
I cut it just enough for the caliper to fit. And then just kinda bent the rest in a way that the big rotor wouldn't interfere. They still shield the ball joints and other parts from brake heat/sparks.
Its not useless. People who just toss them out probably shouldn't be working on cars.
The 04-08 Acura RL has 12.8" rotors. If you want to go with new shields, *maybe* those would work. But to install a new shield, you'll need to press the hub out of the spindle, and buy new wheel bearings...and likely a new hub...and press it all back in.
Old Jun 15, 2018 | 09:06 AM
Tyson's Avatar
its only useful to shield the rotor from grease when a CV axle leaks or blows.
other than that its inhibiting cooling of the rotor.
Old Dec 16, 2018 | 07:34 PM
junior40er's Avatar
if you track your car and are a heavy braker then the shield doesn't help with cooling.
VeeSykkz
Aug 27, 2014 06:31 PM
Kgill23
Aug 7, 2010 10:41 AM
Jellotree
Honda Civic (2001 - 2005)
10
Sep 14, 2008 05:00 AM
hondacivic2005
Jun 18, 2008 06:07 AM
superburner2
Mar 13, 2005 11:21 PM
