Low idle while coming to a stop and turning off out of nowhere while driving
Old Jun 14, 2018 | 05:49 AM
GerardoSG21's Avatar
Default Low idle while coming to a stop and turning off out of nowhere while driving
Hello everybody, I have. 1995 Honda Accord Ex 2.2l Manual transmission that is starting to idle very low when im getting to a stop and the car shuts down on me out of nowhere too. The car seems to hesitate or lose power while im in high gears as well. I just recently cleaned out my throttle body, IAC valve, EGR valve and replace my radiator as well. So Im having problems on where to direct my attention too with this problem. I replaced my fuel filter about 3 years ago and fuel pump as well. Doed anyone have an idea of what can be causing this frustraring issue? Any advice will extremely appreciate. Thank you for your time.
Old Jun 14, 2018 | 07:27 AM
Default Re: Low idle while coming to a stop and turning off out of nowhere while driving
To add to this.. my car also idles low, like it wants to die/turn off, when I start her up to warm her up before taking off to work, sometimes it dies before it warms up completely.
Old Jun 14, 2018 | 08:32 AM
somick's Avatar
Make sure you do not have air packets in your cooling system.
Park the car nose up with the open radiator cap and let it idle. Add some coolant as necessary.
Good luck,
Sam
Old Jun 14, 2018 | 09:41 AM
Good luck,
Sam
thanks sam. can air in the coolant cause the car to want to shut off/low idle or completely shut off?
Old Jun 14, 2018 | 03:47 PM
hondaslave1342's Avatar
I thought high idle ..sorry..keep us posted
Old Jun 14, 2018 | 08:00 PM
holmesnmanny's Avatar
intake leak would cause a higher idle
​​​​​​try unplugging the connector for the oxygen sensor after the car is warmed up and see if it still does it
it will throw a code, that's ok 'cause we're just trying to isolate
Old Jun 15, 2018 | 04:49 AM
ok I will give that a try this weekend. When the car is warmed up and i disconnect the oxygen sensor, what should happen? And why ?
Old Jul 3, 2018 | 06:57 AM
hey bro, so I replaced my oxygen sensor and the car is still stalling on me. When Im about to change gears, in that quick second or millasecond I take my foot off the pedal to engage the clutch and change gears, my car feels like its pulling back like a loss of power. When I get to certain stops, my car idles low still. What do you think ot can be? My buddy told me it could be the throttle postion sensor or even the entire throttle body...
Old Jul 5, 2018 | 06:56 AM
Kevs02Accord's Avatar
What about the IACV? I had similar issues in my civic, cleaned the valve off and it worked out for a minute its fouled up again, and in short order. I need to replace it.
Ef4doorwagon
17
Apr 6, 2014 03:31 PM
LazyAzn
Honda Civic (2001 - 2005)
Apr 21, 2011 11:04 AM
mkrieger500
Mar 2, 2011 12:53 PM
maxxdout
Jun 21, 2002 06:04 AM
Martaigne
Jun 16, 2002 01:53 PM
