PRE-FILTER main relay
Old Jun 12, 2018 | 06:33 PM
avefun's Avatar
Default PRE-FILTER main relay
95 accord that I can`the find PGM-FI main relay. I have factory manual that says it is in one of three places. 1-Dash to left side of climate control system 2- below climate control system left side upper part of center console. 3- left side of cowl [?.?]. I have looked in all three locations after taking all of it apart, and under dash, and in both fuse boxes. Can anyone tell me where it really is?
Is there a separate fuel pump relay. I find no mention of one but I am open to all possibilities.
Old Jun 12, 2018 | 07:30 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: PRE-FILTER main relay
Main relay(which is also the fuel pump relay, its two relays in one) is located under the dash basically above where the accelerator pedal is. It is a rectangular box, usually gray or black in color, with a brick red bottom . If In its original location it is mounted above the accelerator pedal behind the dash, mounted to a bracket. Should be able to see it fairly easily. Has a four wire flat connector plugged into it.
Old Jun 13, 2018 | 04:32 AM
avefun's Avatar
Mad Mike, thanks! I will check that out.
deadhead23
Jan 15, 2021 10:43 AM
larryg1957
May 24, 2016 02:01 PM
ratbelly
Jul 29, 2005 07:12 PM
simike
Sep 16, 2002 05:05 PM
uneekcrx
Apr 11, 2002 06:59 PM
