Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Accord Main relay 2
Old 05-23-2016, 03:14 PM
larryg1957's Avatar
Default 2007 Accord Main relay 2
Instructions on my fuel injection cleaning system (OTC) says to "Remove PGM-FI Relay 2 at LH side of dash" to disable fuel pump during cleaning process. I've searched relentlessly and so far can't locate it. I've found what I believe is the Main Relay, but no go on "#2". I did find a Fuel Pump fuse (15amp) but removing it also disables the ignition.
Any thoughts much appreciated
Larry
Old 05-23-2016, 04:58 PM
Global Moderator
tech8's Avatar
Default Re: 2007 Accord Main relay 2
PGM-FI Main Relay 2 is the left-bottom relay, just above the fuses, in the driver's under-dash fuse/relay box.
Old 05-23-2016, 05:33 PM
larryg1957's Avatar
Thanks very much Tech8. Will chase it down tomorrow.
Old 05-24-2016, 02:01 PM
larryg1957's Avatar
Found it. Thanks Tech8 it was right where you said. There was no access panel for the relays. Caught a glimpse of them up above the fuse panel and had to remove the kick panel to access it. Mission accomplished - injectors cleaned.
Thanks again
deadhead23
01-15-2021 10:43 AM
Jcgbeasttube
Honda Civic (2006 - 2015)
03-19-2018 10:07 PM
shwanC
15
12-04-2013 12:31 PM
p2805
09-28-2003 10:40 AM
uneekcrx
04-11-2002 06:59 PM
Quick Reply: 2007 Accord Main relay 2
