Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
"Installed pads backwards" now LF/LR caliper seized! 08 tsx
Old Jun 12, 2018 | 03:54 PM
B_Swapped93's Avatar
Default "Installed pads backwards" now LF/LR caliper seized! 08 tsx
Before you think I put the pad material to the outside, that's NOT what happened. Got new pads + rotors directly from my local Honda, put in new pads and rotors. Used brake parts cleaner on both sides of all the rotors, now here's where i'm confused. Below is a pic of EXACTLY how I installed them, wear tab on the outside and at the bottom up front. And at the rear I put the wear tab outside and at the top, Is that not correct? I used an electronic caliper to check both back + front sides of pads they wee the same within 0.15 of an inch. I took it for a small test drive and noticed heavy smoking from the left front, took it to Honda for it's RE-safety and now I find out my left front and left rear caliper are seized. I took them off myself and confirmed this. The right side is totally fine, tho they say they too are backwards?. I've done brakes SO many times before.
Old Jun 12, 2018 | 04:22 PM
grampswrx's Avatar
10 Year Member
Default Re: "Installed pads backwards" now LF/LR caliper seized! 08 tsx
In my experience, the pads only really fit in one way. Maybe the brake job and the caliper seizing just happened at the same time by accident? I have had my calipers be sticky after a brake job.
Old Jun 12, 2018 | 05:36 PM
On the service invoice they put it as "FL/LR" caliper seized due to "excessive heat & pads installed backwards". Only way I can see them being "backwards" is if the pad with the wear tab is supposed to go on the "inside" of the caliper? Yah that crossed my mind, the other side is EXACTLY the same "backwards" and it's totally fine, despite them saying ALL the pads were "backwards".
Old Jun 13, 2018 | 04:07 AM
Upon further inspection, YES I did reverse them.
Now I've found a nice used 2012 TSX front driver caliper. The front should be bolt up and go? the rears are different, I know.
Crxlsturbo
Oct 28, 2011 02:23 PM
Donboss
Nov 10, 2007 10:25 AM
hott-nix
Apr 4, 2005 01:33 PM
Deadly-Lude
Sep 27, 2001 01:06 PM
95gsr
Jul 7, 2001 02:41 PM
