No Start Condition
Hello, our 2012 Odyssey will not start. We check the battery, and starter. All connections are good and the battery and started tested fine. But also when the key is turned to on and the brake is pushed down the gear shift won't move. I can manual bypass and move the gear shift to neutral, but car still won't start. When turning key you can hear the relay in the primary fuse box ticking as well.
Brady Stone
Jan 19, 2016 03:40 AM
FlewByU352
Sep 22, 2011 12:15 PM
MattTwinTurbo
Dec 25, 2003 11:33 AM
