Crank sensor? **Need help**
Old Jun 7, 2018 | 08:39 AM
Quinn Nevarez's Avatar
Default Crank sensor? **Need help**
Can you use a b16a2 crank sensor on a B20B LS VTEC?
Old Jun 17, 2018 | 06:44 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Crank sensor? **Need help**
If the mounting points are the same and you have the star shaped crank timing gear, cause theres 2! one is just the gear teeth and other that has the star around the gear is for the crank signal pick up. and it plugs to the harness your using yes! most B series parts are interchangeable.
hondajoe96
Jul 29, 2013 08:59 PM
Lil Rick
12
Feb 10, 2010 08:36 PM
PARADOX_sf
Sep 30, 2009 12:17 AM
sasap
Apr 10, 2006 10:01 PM
