1996 Accord not turning over
Old Jun 5, 2018 | 03:57 PM
rome90731's Avatar
Default 1996 Accord not turning over
I have a 1996 Honda Accord which used to occasionally have trouble starting and the battery has been replaced as well as the main relay and distributor. The problems persisted despite replacements and eventually the car completely failed to even attempt to turn the engine over.
A code reader always shows the code "P1381".
Voltage was checked at the starter and it was okay. There used to be a buzz sound when first turning the ignition to the "ON" position which is not audible anymore.
Any ideas on what could be the issue?
Thanks!
Last edited by rome90731; Jun 5, 2018 at 04:06 PM. Reason: title fix & added information
Old Jun 5, 2018 | 05:14 PM
angrysmileyface's Avatar
Default Re: 1996 Accord not turning over
Have you checked the ecu for blown capacitors?
Old Jun 5, 2018 | 05:59 PM
rome90731's Avatar
Thanks for the suggestion. I will test the ignition switch with a multi-meter to rule it out as an issue and then buy a new ECU if necessary.
Old Jun 20, 2018 | 03:27 PM
rome90731's Avatar
ECU replaced and car still won't start.
Old Jun 20, 2018 | 06:08 PM
holmesnmanny's Avatar
could be faulty alternator diodes
kv1
Honda Accord (2013 - 2015)
Aug 18, 2019 08:00 PM
r_u_live
26
Aug 13, 2018 07:14 PM
quasar
Oct 13, 2017 04:46 AM
shoeboxbarnes
Mar 20, 2013 01:51 PM
west nile
Dec 2, 2009 11:21 AM
