Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Can I run a K20a in fg2 si?
Old Jun 4, 2018 | 12:41 PM
sammy d's Avatar
Default Can I run a K20a in fg2 si?
Looking for some information about doing this swap. Mainly wondering if I can get a flashpro to run the K20a properly or if the flashpro is only able to be used for the stock z3.
Spun a bearing in my z3 and I have a full K20a here with harness and ecu from an accord euro-R. I know I need to change out the basepan and the intake manifold and throttle body for the DBW setup. I believe I can keep the z3 harness and just change out some sensors/plugs but I may be wrong. Can't seem to find much info about this swap.
Any help is appreciated, thanks
Old Jun 4, 2018 | 07:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Can I run a K20a in fg2 si?
Yes, you can do this swap pretty easy. Swap the oil pan, intake manifold (you will have to cut it for the coolant housing or buy a modified or aftermarket I/M) and DBW throttle body... use the Z3(Si) engine harness and you can tune the car for the engine. I am not sure there is a "basemap" in the library, but if there is, a tune will be quick to touch things up.
Old Jun 9, 2018 | 05:24 PM
sammy d's Avatar
Thanks man sounds good. Getting the engine prepped to go in now. Can I tune the car for the engine using flashpro for a 06-11 si or would I be better off getting a different tuner? Like when I go in to tune it, will there be an option specifically for a K20a type r or will I have to set everything myself. Don't know much about the whole process, this is my first time with k series as well
Old Jun 9, 2018 | 05:29 PM
K20teggg95's Avatar
100% swappable I did this same swap for a customer last year if you need any info shoot me a p.m. i also have a few parts laying around
Old Feb 14, 2023 | 04:47 AM
Jenkins98's Avatar
I just swapped a k20z3 with a jdm k20A. I'm having issues with the clutch not fully disengaging. New clutch,flywheel release bearing, slave and master cylinder. Since the oil pan is different and the bottom half of the transmission isn't supported, would that cause the clutch to not fully disengage? Can i swap the oil pan over from the z3 to the k20a without replacing the oil pump?
Old Feb 14, 2023 | 08:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Your clutch problem is either bad components or improper installation. The oil pan swap has nothing to do with your clutch issues. You need to swap the pan so that you can use the rear dog-bone torque mount. It should not interfere with your oil pump.
tommychong
Mar 14, 2018 11:01 AM
Aponcebmx
Apr 27, 2017 02:15 PM
Eskiee
Nov 22, 2013 07:43 AM
cup cake
Jun 23, 2010 12:26 AM
EastSideRacer
15
Nov 10, 2009 08:09 AM
