Honda CR-V & Element 2WD & 4WD Element & CR-V
Oil pressure light flickering
Old Jun 4, 2018 | 03:02 AM
gonzo62's Avatar
Default Oil pressure light flickering
Back in about February I had the oil pressure switch replaced,aftermarket, leaking. A couple days ago I noticed that when the engine is fully warmed up, after about 6-7 miles, the oil pressure light will flicker at idle. But the warm idle is rough and about 600 - 700 rpm. Above that the light is out. A low rough idle is the only time I see it. Question is do I go after the idle issue first or the oil pressure light ? Thoughts?
Old Jun 4, 2018 | 04:58 AM
gonzo62's Avatar
Default Re: Oil pressure light flickering
Talked with my usual mechanic. He said it could also be that the engine is tired and the pump can't keep up with the wear in the bearings and such. It does have 200,000 miles. But why only when it's warm? Thoughts?
Old Jun 4, 2018 | 05:57 PM
holmesnmanny's Avatar
best thing to do is to have a mechanic hook up a gauge and see if pressure really is bad
Aaronw93
12
Mar 3, 2014 10:18 PM
curtie94
Jun 22, 2011 06:34 PM
Silver89crx
17
Aug 25, 2009 04:46 PM
blinger
32
May 30, 2007 05:58 AM
turboh22chick
Jan 13, 2005 09:09 PM
