Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Honda Civic Overheating + Radiator fans not turning on?
Old Jun 3, 2018 | 01:30 PM
Nuktuk's Avatar
Default 2002 Honda Civic Overheating + Radiator fans not turning on?
I have tested the relays, the fuses, and the fans itself, all of them work.
I used a safety pin to complete the circuit in the cable that attaches to the thermostat fan switch (the switch that is part of the thermostat housing) which DID turn my radiator and A/C fan on, so I know the fan's work from that. I figured the switch was bad, so I replaced the switch with no success. I then replaced the thermostat, it's still overheating and the fans are still not turning on.
The top hose gets very hot where I cannot touch it, however the bottom hose stays warm and I can keep my hand on it without being burned.
I am very confused on what could be keeping the fans from turning on. The car overheats and the temperature gauge goes to the hottest, so the fans SHOULD be turning on.. If anyone has any other tests I can run or have any ideas I'd be happy to hear them.
Edit: Here is a video explaining the safety pin method I used to test, only need to watch for about 40 seconds:
Old Jun 5, 2018 | 01:27 PM
thisguyaves's Avatar
Default Re: 2002 Honda Civic Overheating + Radiator fans not turning on?
The fan switch is in the bottom of the radiator, as you know... If the bottom of the radiator isn't getting hot, your fans would not turn on. If the bottom of your radiator isn't getting hot, I would burp the cooling system thoroughly, and if that doesn't fix it I'd suggest a water pump.
Old Jun 5, 2018 | 02:05 PM
Nuktuk's Avatar
Isn't the switch in the thermostat housing? That's where I see it on mine (honda civic 2002 EX 4 door) it also shows it there in the video...or is that not the switch?
Old Jun 5, 2018 | 02:30 PM
Oh, my mistake, I was thinking about my Si. Yes, it's in the thermostat housing, but my comment still stands- poor circulation due to air bubbles or bad water pump could still be causing this, since the thermostat is basically the intake from the bottom of the radiator. A good way to test this would be to idle until your operating temp is reached, then manual turn the fans on. If you don't see the temp fall quickly, you have a circulation issue.
Old Jun 5, 2018 | 02:44 PM
Nuktuk's Avatar
Operating temp would be near the half way mark right? Okay so here is one more question that I am really curious about....
My A/C Light comes on in the interior when I press it to turn it on...but the condenser fan does NOT turn on. Could this be related to the radiator fan not turning on when it gets hot enough as well? Here is a diagram of the circuit to help you understand:
https://www.manualslib.com/manual/12...age=203#manual
Let me know if I can provide you with anymore details or resources!
Old Jun 6, 2018 | 12:35 AM
holmesnmanny's Avatar
if you're able to jump it then you either have the wrong fan switch or the connector is bad
Old Jun 6, 2018 | 07:19 AM
Correct, operating temp is a tick or two below 1/2. AC is a complicated beast, there are a lot of variables, but the two fans are not connected as far as I know.
Old Jun 6, 2018 | 06:44 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Both cooling fans should be running at the same time when the A/C is on or if the coolant temperature at the radiator fan switch is above 199 degrees F.
Old Jun 6, 2018 | 07:10 PM
Nuktuk's Avatar
Yeah so I guess I should try and find out why the fans don't come on when the A/C is on either.
Old Jun 9, 2018 | 07:01 AM
Sounds like a fuse or relay issue. Does the AC actually work? If it gets cold only when driving forward at 30+ mph, then I'd definitely chock it up to an electrical problem. AC fans will not ALWAYS be on, they switch when the thermostat in the condenser tells them to.
Justin Ripley
17
May 13, 2017 12:19 PM
chellerfl
Jul 13, 2016 07:43 AM
dman81
May 28, 2014 03:20 AM
herngonz
Jan 2, 2014 09:26 PM
intekragsr
Feb 27, 2003 02:14 PM
