F20B Axles?
I have a 96 EK with a f20b swap I bought off my buddy that got it from a ******* that likes to half *** ****, So i picked it up and im trying to get it going again. I am putting a new clutch in and when i went to pull the driver side axle I discovered the boot was ruined and the axel was shot. Can anyone tell me if a h22 axle will work, I also read that i might have to hunt down old integra axles??
Here’s the Axles I pulled out of the Driver side. One boot is labeled, BT-332 the other is BT-187 the inner half has the support bracket that bolts to the back of the block I’m just try to figure out this set up.
First google search I did pulled up a solid H-T thread for this exact setup:
https://honda-tech.com/forums/hybrid...shaft-1242510/
In the above listed thread then also points you to a sticky:
https://honda-tech.com/forums/hybrid...%2A%2A-650329/
Which has the break down of a lot of the swap including axles.
