Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
SRS light intermitent
Old Jun 2, 2018 | 10:16 AM
Bearski's Avatar
Icon5 SRS light intermitent
Hi there, being a newbie here I have a problem with SRS, check airbag system lighting up intermittently, was re-flashed. Got another module and this one also re-flashed but SRS check stays on so put original one back in. Still comes on intermittently. Checked a lot of different connections that were worked on (Rebuild status vehicle). Not sure where to proceed. May check clockspring/connection as that was replaced but this isn't making any sense as to why one unit displays check light all the time, not coming off, while the other is intermittent. HELP please. Also my Autel unit says no communication but is only good up to 2012 and I can't find update for this unit as Autel doesn't display that for my particular scan tool. not sure why as it was purchased in 2012.
Old Jun 4, 2018 | 07:28 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: SRS light intermitent
sad to say you most likely have the nightmare of a "loose/frayed/raw" wire *somewhere*
alldata would be able to tell you what wire and where
jdmasfuk
Jul 21, 2009 06:35 PM
GRPNHRD
Sep 28, 2005 10:12 PM
ih8danoles
Aug 12, 2003 10:13 PM
hondaZvic
Oct 9, 2002 09:01 PM
