Back up lights and meter lights fuse 97 lx
Check engine light flipped on so I was on my way to AutoZone to check it and I popped #1 fuse or 16 in manual. Lost all dash gauges and lights and the brakelight and after parked wouldn't shift out without key entry. Now the weird part is when I replaced fuse it started smoking from the engine even with the car off so there's wires burning somewhere. I replaced the tss since that's the code it brought up and it was reading higher resistance.
anyone know what wire cluster/switch it is that's burning/a diagram? My electrician buddy said he needs to know more on integrated circuit g1
The missing fuse in the photo is the one that starts the smoking when replaced.
For a 97 LX with automatic transmission, under-dash Fuse No. 1 protects the following components:
If the brake lights are out, you'll want to check under-hood Fuse No. 30 (20A) and the wiring related to that too.
- Integrated Control Unit (this is attached on the under-dash fuse/relay box)
- A/T Gear Position Switch - (part of wiring harness inside of cabin)
- Shift Lock Solenoid (part of wiring harness inside of cabin)
- Clock - (part of wiring harness inside of cabin)
- Gauge Assembly - (part of wiring harness inside of cabin)
- VSS - (in engine compartment, part of engine wire harness)
andyw1214
Nov 14, 2016 10:41 PM
EJ8CIVIC
18
Feb 8, 2008 04:18 AM
