A/C pressure switch
Old May 30, 2018 | 10:03 PM
Freedo_Civegra's Avatar
Default A/C pressure switch
Is the a/c pressure switch that mounts on the drier/reciever designed to cut out under BOTH low and high pressure, or ONLY low pressure?
Old May 30, 2018 | 10:23 PM
tony_2018's Avatar
Fish Twig
Default Re: A/C pressure switch
low pressure only from what I've experienced. You can jump it too to enable the compressor for testing purpose.
Old May 31, 2018 | 03:40 AM
mk378's Avatar
It is supposed to cut off if pressure is < 50 psi or > 450 psi. These pressures only happen when something is wrong. The switch will be closed at all times during normal operation.
Do not jump the switch unless you have gauges connected and are watching the high side pressure.
Old May 31, 2018 | 04:38 AM
tony_2018's Avatar
Fish Twig
many yrs in ac business, never needed high side port.
Old May 31, 2018 | 04:41 AM
Thanks! Tony said “for testing purposes”. I wouldn’t do that unless I was testing the clutch coil for a second or 2.
I have A/C in my J-swapped Civic, and I think this means I need to add a low side cycling switch. Since I have no other modules to govern when the ECU turns on the condenser fan and clutch coil relays, I had to wire them both up through the a/c thermostat to be grounded by the a/c switch.
The Accord ECU has switched grounds for these circuits and switches them on via signal from the BCM (which is not present on the Civic) through CAN wiring.
Old May 31, 2018 | 04:54 AM
And there’s not one on this system. 👍
Old May 31, 2018 | 05:24 AM
mk378's Avatar
If it's still a TXV system it should be set up to cycle on evaporator temperature. Pressure cycling is for orifice tube systems. That pressure switch is on the low side.
The only modification really needed is what you've done: connect the compressor and fan relay coils directly in parallel instead of having the compressor loop through the ECU, BCM etc. The loop through the ECU is not for pressure or temperature control. It is so the ECU can pre-emptively increase the idle air before the compressor engages.
Old May 31, 2018 | 05:40 AM
Yup, I thought about the ‘spansion valve just a few minutes after I posted that. Had a long night... Been having problems on the condenser getting heat soaked. It was cold this morning, but it won’t when it’s hot out. I’ve got a full-size universal EBay condenser coming.
Old May 31, 2018 | 06:24 AM
tony_2018's Avatar
Fish Twig
I would just wait until you get the full size condensor before doing any more testing. I looked up condensers for an 05 honda accord v6, since you didn't specify a yr I'm guessing it was that generation (not in your build thread either), and the condenser in that model is 25 3/4 x 14 15/16 x 5/8. You sir are undersized by using a 12 x 24
Old May 31, 2018 | 06:45 AM
You’re right on the testing. That’s the advice I usually give customers! Wish I’d listen to it.
2003 Accord EX coupe is what the swap is from. Don’t know why dummy didn’t put it in the build thread.
12x24 as big as I think I can fit properly without cutting the bumper cover to shreds. It’s better than the 12x14 I have now.
tony_2018's Avatar
Fish Twig
Can only hope.
edit: would the integra condenser work?
Old May 31, 2018 | 09:49 AM
Can only hope.
126 cu in (currently)
157 cu in Civic unit
211 cu in (12x24 unit ordered)
240 cu in Accord unit
250 cu in Integra unit
The Teg condenser has the highest volume, but I would need more specialty fittings and have the hoses remade. A unit 14 x 24 x 3/4 would be slightly greater than the Integra condenser by about 2 cu in. If I had the space, I’d use that.
Old May 31, 2018 | 10:00 AM
tony_2018's Avatar
Fish Twig
Is the compressor same between K and J series? Never looked. Also the crv uses a full size condensor too, engine bay is similar to the civic. Have you looked into that?
Old May 31, 2018 | 01:36 PM
Denso has different part #’s on the Accord 2.4 and 3.0.
CRV condenser is dimensionally the same as the Integra.
Their bays are quite similar, but that thing’s not fitting in the normal spot:
You can’t really see it too well, but that O2 sensor, exhaust pipe, and compressor really aren’t going to make good friends with a CRV or Integra condenser mounted on the backside of that radiator support.
Old May 31, 2018 | 02:16 PM
tony_2018's Avatar
Fish Twig
Sucks
Old Jun 1, 2018 | 09:10 AM
Sucks
like a 3-day-old kitten.
hall97civic
May 24, 2015 12:54 PM
cueto
22
Aug 4, 2011 07:02 PM
powerflow
Aug 28, 2009 11:16 AM
nmhuntr
May 9, 2009 05:31 PM
