maitnence light
Old Nov 12, 2002 | 05:34 PM
jonoknut's Avatar
Default maitnence light
i know there are always questions about maintenence lights, but i searched and didnt find anything about, if the light actualy tells if there is somehting wrong, or its just a big gimmick like i heard to make u bring it in to the dealer. . or what. . cxus mine when on it blinks 9 or 10 times whne i starty the car then goes away so im not sure if i should ignore it or not, im at 91k miles, and the 90k mile service was already done at 88k miles. suggestions, ideas or know anything about the light?? thanks
Old Nov 12, 2002 | 05:56 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: maitnence light (jonoknut)
press the button under the dash, nix the light. if you already did the service then no point in doing it again.
Old Nov 12, 2002 | 05:58 PM
Mr.Rab's Avatar
Default Re: maitnence light (dLo GSR)
Do a search in the owners manual.
Old Nov 12, 2002 | 06:20 PM
iH8RICERZ's Avatar
Default Re: maitnence light (Dr. RAB)
but to save you some time, theres a blue button underneath the dash right underneath your steering column. Turn the key to power, hold button in until the light goes away, and BAM, its gone!!!
Old Nov 12, 2002 | 06:27 PM
MrBite's Avatar
Are you talking about the one that's loosely engine-shapes and says "CHECK" or the one that says "MAINTENANCE REQUIRED" or something along those lines?
The check engine light means something's amiss, the maint. req. light can be turned off with the under-dash button as these **** have said. It just means you have to like...change your blinker fluid.
Old Nov 12, 2002 | 07:15 PM
samagon's Avatar
Default Re: maitnence light (MrBite)
lol bite, that would suck, he would come back and complain that it didn't fix it and drive his car around like nothing is wrong.
as for why the search didn't pick anything up, try using the archive as a search area. I, supprisingly, haven't seen a topic on this is a really long time.
where is that ghetto picture of the reset light that they had floating around the ITR forum so many years ago?
hahaha! found the image.
and here are the results of my search, don't know about no topics on it...
https://honda-tech.com/zerosearch?id=1725219
[Modified by samagon, 10:23 PM 11/12/2002]
Old Nov 12, 2002 | 07:29 PM
deMad10's Avatar
Default Re: maitnence light (samagon)
Nice drawing...
Do the maintance as well as push the button...it doesn't come on for nothing...
Old Nov 12, 2002 | 07:59 PM
jonoknut's Avatar
Default Re: maitnence light (deMad10)
i just dont want to be missi sumthing, im going to go ahead and turn it off, hopefully itll be all good huh.
bulig06
Aug 5, 2010 11:42 AM
ekdriven
Jun 3, 2004 08:21 PM
NelsitoTeg
May 26, 2004 06:57 PM
redteg1
Oct 14, 2002 04:40 AM
Unlimited
Aug 11, 2001 11:10 AM
