no crank no start
Old May 28, 2018 | 10:52 AM
Wesleyej1's Avatar
Default no crank no start
Hello,
My civic got stolen, they did not have my key, they broke my ignition switch and I replaced it. But when I turn my key nothing happens. No lights come on, but I do here the beeping noise telling me I have my key turned. I do not here my fuel pump harness priming
Can you help
Old May 28, 2018 | 02:25 PM
mk378's Avatar
Default Re: no crank no start
The "oil" and "battery" lights must come on whenever you turn the key on but the engine is not started. Power for those comes from the same circuit that operates the ECU, fuel injectors, ignition, etc. They should light up even if there is a problem with the ECU.
So look for fundamental problems like blown fuses, cut wires, and missing parts.
Old May 28, 2018 | 05:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Did you re-install the electrical switch (pigtail) on the opposite end of the key lock assembly as the key ??? If not, you can turn the slot in the electrical switch with a flat blade screw driver and rotate it to see if the dash lights come on and if you hear the fuel pump cycle and main relay click. If you turn it all of the way on you will hit the START position.
Old May 29, 2018 | 09:49 AM
Wesleyej1's Avatar
Nothing comes on. The oil lights do not come on. When I turn my key literally nothing happens. The cylinder went bad so I took the ignition switch and turning it from there. I am not getting any power to my fuel pump or cluster. I jumped the started and it works. I am stuck...
Old May 29, 2018 | 09:50 AM
Wesleyej1's Avatar
I did check fuses and all look okay. I literally took them all out one by one to verify.
CptHMCrunch
Apr 1, 2014 11:03 AM
kevpple
Nov 14, 2010 04:05 PM
ImportechPerformance
Jul 26, 2010 07:05 PM
slow joe
Jan 14, 2010 12:58 PM
