dist question
Old Nov 12, 2002 | 05:21 PM
ImportHatch's Avatar
Default dist question
I got a d16y7 motor in my crx and its gonna be runnin a a6 ecu. My question is, is the only dist i can use the a6?
Yager-
Old Nov 12, 2002 | 05:55 PM
Jared's Avatar
Default Re: dist question (ImportHatch)
with the a6 ecu you can only run an a6 ecu.
Old Nov 12, 2002 | 10:00 PM
Default Re: dist question (Jared)
are you 100% of that? Someone else told me I could run a hf dist.
Yager-
Old Nov 12, 2002 | 10:36 PM
LB CRX's Avatar
ummm am i reading this right? he just repeated the same thing twice
Old Nov 12, 2002 | 10:40 PM
Default Re: dist question (LB CRX)
Im sure he meant a6 dist.....
Yager-
[Modified by ImportHatch, 11:42 PM 11/12/2002]
Old Nov 13, 2002 | 10:24 AM
ttt
Old Nov 13, 2002 | 11:45 AM
Katman's Avatar
Yager-
I personally, performed this exact swap in an 89 Si hatchback a few months ago. We retained the Si/D16A6 distributor which bolted right up to the Y7 head, no problemo. The tricky thing was the spark plug wire configuration...it was a little funky but it works.
Actually, you should be able to use any 88-91 SOHC distributor on a Y7 head, but I strongly suggest you stick with a distributor that came from a multi-port fuel injected (4 injectors) engine (Si or HF).....as the dual-point engines have a distributor with a square plug and can make things difficult.
[Modified by Katman, 12:46 PM 11/13/2002]
Old Nov 13, 2002 | 12:54 PM
Default Re: dist question (Katman)
Thank you Katman, Just the info that I have been lookin for.
Yager-
Old Nov 13, 2002 | 02:46 PM
Katman's Avatar
Yager-
word up.
Randysi
49
Oct 30, 2011 09:54 PM
ef89
Jan 25, 2009 03:39 PM
soundman
May 8, 2003 06:38 AM
ImportHatch
Nov 12, 2002 08:33 PM
