B16 internal block parts into a JDM B18C. Possible to work properly?
Old May 27, 2018 | 08:33 AM
B18C Type R!'s Avatar
Default B16 internal block parts into a JDM B18C. Possible to work properly?
I have a 95 JDM B18C Type R and was curious if the pistons, rod, crank, oil pan ext From a b16a2 will fit into the B18C?
Im looking to rebuild and have found a good source of parts that are decently priced the only thing is they are from a b16a2 and thats where my question comes in.
Thanks in advance guys!
Old May 27, 2018 | 10:35 AM
Chance EG's Avatar
Default re: B16 internal block parts into a JDM B18C. Possible to work properly?
Rods will not work, the deck height of B16a is shorter than the rest of the B family. You'll need custom length rods in order to use the B crank within the B18C block.
Old May 27, 2018 | 09:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yeah, the crankshaft would work, but you would have to use B16B (CTR) rods and pistons and then you would basically have a CTR engine. I am not sure of any good reason to do this on a street car... the ITR engine is a much better overall engine.
Old May 30, 2018 | 04:43 AM
AllMtrRex's Avatar
Correct. Also, B16B and B16A do not share the same rod width - bearing size.
061000rr
Sep 24, 2009 02:08 AM
uniquewheels08
Jan 2, 2009 07:38 AM
Wytek9
Apr 23, 2008 09:32 AM
Chief Wenceslaw
13
Jun 24, 2006 05:03 PM
Deetz
Sep 21, 2004 01:36 PM
