Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
towing 2018 hrv with smart entry system
Old May 26, 2018 | 11:43 AM
hrvtoad's Avatar
Default towing 2018 hrv with smart entry system
HRV is FWD and Manual Transmission. Is the difference in towing hrv behind a rv and pulling 3 fuses based on time only? Extended towing (8 hours plus) pull 3 fuses while "normal" towing (less than 8 hours ) fuses can remain in vehicle and operational since hrv ignition must be in accessory mode either way. the fuses are interior fuse block 20A accessory power socket and 7.5 A ACC fuses and in engine compartment 10A Back Up fuse. Am I correct that the reason the fuses must be pulled in extended towing is that the power draw will drain the battery? Is there additional problems if they are not pulled for extended towing?
arborguy
Honda Civic (2006 - 2015)
11
Dec 28, 2016 05:29 AM
Daghda
Honda CR-V & Element
Sep 21, 2013 06:17 AM
Akura
Audio / Security / Video
Jul 20, 2004 06:07 AM
cd5_2NR
Jul 1, 2004 01:38 PM
