5th Gen 2000 SH WHEEL AND TIRE UPGRADE
HELP! Want to upgrade stock 16 in rims on my 2000 Prelude SH to available 2018 Honda 17 x 17.5 rims and mounted tires 215-55-17, bolt pattern same, WILL THIS SETUP FIT? concerned about clearance front and rear and turning front end geometry issues...
Depends about offset
55 would firstly look horrible and secondly could cause problems. Id go 45
There is calculators in Internet to see how much the diameter changes...
The wheel will likely work... the tire is too tall. You will need to run either a P205/45R17 or a P215/40R17. These two choices are .25" taller and .25" shorter than stock respectively.
drummer4hire
17
May 28, 2018 04:36 AM
