Honda CR-V & Element 2WD & 4WD Element & CR-V
99 Honda CR-V timing bay issues/ rubber shavings
Old May 24, 2018 | 07:51 PM
RickHunter's Avatar
Default 99 Honda CR-V timing bay issues/ rubber shavings
Hello, about two days ago I was riding on the expressway when I heard a pop and some grinding noises, the engine totally cut off but thankfully due to the speed/ momentum, I was able to pull safely to the side of the road. Fast forward a day, the CR-V is back at my place and I removed the valve cover for further inspection. The timing belt seems to be in one piece but I found a bunch or rubber/plastic shaving material all around the cam sprockets and inner valve cover. The sprockets do look out of alignment from what I've seen .Does anyone knows where does this may be coming from? I guess I'll eventually dig deeper into the engine but I'd like to know what to expect. Thanks for any replies.
Pics.
Old May 27, 2018 | 05:27 PM
RickHunter's Avatar
Default Re: 99 Honda CR-V timing bay issues/ rubber shavings
A quick update, it was the timing belt. It didn't snapped but many teeth failed and it was all chewed up. Installed a new one and thankfully everything seems to be ok so this CR-V lives another day.
Old Jun 8, 2018 | 09:56 AM
B20Zer's Avatar
Lucky call, could have been an expensive repair, any idea why the belt failed, when last was it replaced?
roadsqueegy95
15
Jun 7, 2012 09:22 AM
nik1703
Honda Civic (2001 - 2005)
Jun 21, 2010 08:35 PM
flangemastermike
Jul 18, 2008 11:59 AM
xxmastermindxx
Sep 11, 2006 08:18 PM
DLB1994
Dec 25, 2001 10:50 AM
