Scanner for Throttle Position reset
Hello,
If you are talking the RAW data setting in the rheostat throttle pedal this comes factory set. However if you are having problems with the throttle sensor which I believe you are, then the attached pdf should help.
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
