Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
AC/Defrost Nearly Stalls Car
Old May 24, 2018 | 10:28 AM
Big Bad Bear's Avatar
Default AC/Defrost Nearly Stalls Car
Hello,
I have an 05 Accord with the 2.4 VTEC. When ever the AC clutch engages my RPMs drop from about 900 to 500, shaking the car and nearly causing a stall. To compound this problem, by Accord is a manual transmission. So when I push the clutch to shift gears, if the AC clutch is also engaged, this causes difficulty steering. I have already replaced the idle air control valve, throttle position sensor, and have a brand new AC compressor. None of this fixed my problem. I also cleaned out the EGR valve, which helped slightly in that the RPM now drops to 500 when the AC engages, but then rises to about 600, but the shaking and trouble steering continues. Any suggestions?
Old May 26, 2018 | 05:36 PM
holmesnmanny's Avatar
Default Re: AC/Defrost Nearly Stalls Car
when were the plugs replaced ? how many miles ? scan for codes ?
Old May 26, 2018 | 07:26 PM
I replaced the plugs about 6 months ago with NGK Iridium plug. I did the pcv at the same time.. Serp belt is about 1 year old. I just replaced the tensioner pulley as well. No codes. What else can you think of?
Old May 26, 2018 | 10:58 PM
Your issues could be indicative of a lazy oxygen sensor. The ecu will enrich the mixture when the compressor engages. If the sensor is lazy it might be able to properly enrichen the mixture right. This would also correlate with the clutch switch causing the car to hesitate. Has the upstream sensor ever been replaced ?
Old May 27, 2018 | 08:22 PM
I have not replaced with the up or down stream sensors. I did replace the cat a while ago though. Do you know what the specs should be? I can get a OBD2 reader and see what its putting out.
Old May 29, 2018 | 09:09 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Originally Posted by Big Bad Bear
Hello,
Sounds like the charge is low. Take it to a shop and have it checked.
Old May 29, 2018 | 10:06 AM
I appreciate the thought. I replaced the AC Compressor and had it charged at a shop. The problem continued after having it properly charged.
Old May 29, 2018 | 10:49 AM
you can backprobe the sensor and test the voltage, it should oscillate quickly from .10 to .90 volts after being warmed up
FatboyNYC
Honda CR-V & Element
Jul 11, 2018 01:45 AM
Bobs2008Civic
Honda Civic (2006 - 2015)
13
Aug 9, 2017 05:33 AM
ellisshaun
Apr 28, 2014 06:35 PM
johnehonda
10
Jul 4, 2012 08:13 AM
adan CRX
Nov 26, 2003 08:41 AM
